How to check a crystal
Discussion in 'General Electronics Chat' started by nerdegutta, Feb 27, 2010.
  1. nerdegutta
    Thread Starter Moderator
    Dec 15, 2009
    2,565
    805
    I have a bunch of crystals, with 2 pins and 4 pins.
    I have a frequency counter, and I can test the 4 pins, but how can I easily test the 2 pins?
    Maybe I need a little circuit?
  2. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,386
  3. nerdegutta
    Dec 15, 2009
    2,565
    805
    Thanks.
    Guess I can use a BC549c, instead of the BC550c?
    I compared their datasheets, and to me they seem to be pretty like.
  4. t06afre
    May 11, 2009
    5,939
    1,222
    The BC550 and 549 are compatible. The BC550 can be at higher voltages than the BC549. But at 9 volt this does not matter at all
  5. nerdegutta
    Dec 15, 2009
    2,565
    805
    Thanks. I will try to build it now.
  6. nerdegutta
    Dec 15, 2009
    2,565
    805
  7. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,386
    Strange that you could not get the x-tal tester to work.
    The schematic you posted is basicaly the same.
    Bertus
  8. nerdegutta
    Dec 15, 2009
    2,565
    805
    Yes, I noticed that too.
    On the last circuit, I changed the BC549 to 2N2222. Maybe thats why?
  9. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,386
    That could be.
    The BC549 is an audio transistor.
    The 2N2222 is a switching transistor, that might be more of use for the circuit.
    Greetings,
    Bertus
  10. Wendy
    Mar 24, 2008
    20,772
    2,540
    Uhh, guys, protoboards and crystals do not get along. You are loading a sensitive circuit down with a heck of a capacitance.
