How to charge electrodes?
Discussion in 'General Electronics Chat' started by kconrad, Oct 9, 2009.
  1. kconrad
    Oct 9, 2009
    9
    How do you positively charge and negatively charge electrodes? Is this done with some type of equipment or can it be done with batteries? Need to know for school homework. Thanks.
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
  3. kconrad
    Oct 9, 2009
    9
    beenthere,
    Thank you for the reply. To use a battery would I just connect the anode, for a positive charge, to the surface of the item I want to positively charge? Don't I have to also hook up the cathode to get a closed circuit?
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    You can transfer a static charge, per the Ebook chapter, but merely touching an item to the battery's anode will not charge it. The terminals of the battery are electrodes, and are changed by the internal electrochemical activity.
    A connected external circuit is not usually though of as having it anode connected to the battery positive terminal, nor the cathode to the battery negative terminal. They are simply electrical connections.
    Can you expand on what is is you mean by "electrode".
  5. kconrad
    Oct 9, 2009
    9
    All I mean by electrode is a conducter used to connect to the component (or substance) I'm trying to ionize. So the electrode is basically the end of a wire.
  6. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
