How to charge a laptop battery using solar panels
Discussion in 'The Projects Forum' started by mm0hai, May 19, 2012.
  1. mm0hai
    May 19, 2012
    Did you have any luck with this? I'm trying to do much the same thing.
    Currently, I think I'll probably use a smart battery SMBus charger IC and charge the battery externally. I suspect this will be necessary because I don't think the internal charger will work if there is not enough current for a full rate charge. I've not tested this assumption though.
  2. evilclem
    Member
    Dec 20, 2011
    118
    16
    I would put a 12V lead acid in the middle, charge the lead acid with a solar charge regulator and use a standard DC-DC converter to power the laptop.
    I would avoid bypassing the laptop charge controller, lithium batteries should never risk being mistreated.
    It should be noted that this exercise is only useful if you run your laptop for a few hours a week, otherwise a large solar array is required.
  3. Wendy
    Mar 24, 2008
    20,772
    2,540
    Welcome to AAC!
    A thread belongs to the OP (original poster). Trying to take over someone elses thread is called hijacking, which is not allowed at All About Circuits. I have therefore given you a thread of your very own.
    This was split from How to charge a laptop battery with a solar panel ?
  4. rohitd
    Jan 29, 2011
    14
    the most important consideration in a laptop chager is the wattage it can provide. if you are charging a laptop from any other source than a specified charger, then you must be able to run the laptop without the battery on that charger. If the charger doesnot match your laptop, you battery doesnt get charged, moreover it gives message regarding that. the battery inside the laptop is a smart battery and canot be altered easily. I have myself played alot on it. to charge the battery efficiently, see the current and voltage ratings on the charger output side and make your charger accordingly. use some secondary source in between as said by 'evilclem'. solar output is never the same even for any 10 seconds!! this will definitely spoil your battery. use BQ2031 regulator for some lead acid battery charging from the solar pannels, from the battery do the charger construction according to charger specs. this will definitely work
  5. t06afre
    May 11, 2009
    5,939
    1,222
    Modern laptops do not accept charging from a non original chargers. It may probably work using the non original charger as current source. But it will not charge
