how to change negative pulse to positive pulse?
Discussion in 'General Electronics Chat' started by radetonator, Sep 22, 2011.
  1. radetonator
    Aug 1, 2011
    50
    For the pulser circuit shown below, the output pulse is negetive. If BNC need to be connected to the load, how can output pulse be positive?:confused:
      File size:
      13.6 KB
      69
      File size:
      9.6 KB
      55
  2. MrChips
    Oct 2, 2009
    12,642
    3,457
    Use a single stage common emitter circuit with an NPN transistor, similar to the one shown in your circuit.
  3. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    Use transistor or MOSFET ....
  4. radetonator
    Aug 1, 2011
    50
    What if the voltage is 1KV, pulse duration is 1ns?
  5. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    Then i think it will be not easy...!!
    or use step transformer ( Fly back)
  6. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    What in the world are you working on that outputs a 1nS -1kV pulse?
    I hope you realize that a 1nS pulse will require a circuit with a bandwidth >= 10GHz in order to make a reasonable facsimile of the pulse, but inverted, right? That's in the radar X-band RF spectrum. At those frequencies, a tiny kink in a wire acts like an inductor. It's even difficult to use multilayer ceramic caps due to their parasitic inductance.
    In the beginning of your thread, you posted a waveform that's practically identical to the one in this thread:
    http://forum.allaboutcircuits.com/showthread.php?t=59546
    and the OP is wanting to invert the signal, stretch the pulse, and detect it using a microcontroller.
  7. MrChips
    Oct 2, 2009
    12,642
    3,457
    Looks like some kind of charged particle or gamma-ray detector.
  8. ahsansahab
    Sep 22, 2011
    6
    use an emitter follower op amp.
  9. MrChips
    Oct 2, 2009
    12,642
    3,457
    Emitter follower does not invert.
  10. radetonator
    Aug 1, 2011
    50
    The pulser i am working on is not the one as shown in the beginning of the thread. But the structure of the output stage is the same-- a capacitor and a load resistor. The current flows from GND to the load. So that pulse is negative.
