How to change duty cycle in voltage to frequency converter using LM331
Discussion in 'General Electronics Chat' started by Amol Sakhale, Jul 1, 2015.
  1. Amol Sakhale
    Jun 12, 2015
    5
    How to change duty cycle in voltage to frequency converter using LM331???
  2. AnalogKid
    Distinguished Member
    Aug 1, 2013
    4,699
    1,298
    Your question does not contain any information, so it can not be answered. You told us nothing about your application. What signal voltage, waveform, amplitude, frequency range, output voltage range - nothing.
    Read the datasheet. It has seven circuit designs for different applications and the design equations you need. Pick the one that is closest to your application, modify it to suit your needs, and post the schematic so we can see your work. Then ask questions.
    ak
  3. crutschow
    Mar 14, 2008
    13,501
    3,375
    That circuit does not appear to readily allow adjustment of the output duty-cycle.
    Why do you want to?
  4. ian field
    Oct 27, 2012
    4,455
    792
    This device was popular in the early SVGA and multisync monitors, as it can be configured as voltage to frequency or frequency to voltage, so it was used as part of the VGA mode detection from the sync pulse frequency. Monitor schematics from that era are likely to show various ways of connecting this chip.
    There were Sharp and Raytheon pin for pin equivalents, but the numbers don't suggest it - so it can take a bit of detective work and a few equivalents charts.
  5. ian field
    Oct 27, 2012
    4,455
    792
  6. ian field
    Oct 27, 2012
    4,455
    792
  7. crutschow
    Mar 14, 2008
    13,501
    3,375
    Why are we looking for equivalents of the LM331?
  8. ian field
    Oct 27, 2012
    4,455
    792
    More different numbers for the same chip to look for appnotes under.
    RichardO likes this.
