Hai, i have constructed a simple light sensor using ldr, the output is amplified and given to micro-controller. I want to calibrate the sensor but i dont know how to calibrate the sensor. Can you help me to calibrate it????????????????
Provide the sensor with a repeatable/fixed light source and set the output to what you want.
Like using a light bulb and always setting the sensor a fixed distance from it.
