How to calculate the voltage of the given diagram?
Discussion in 'Homework Help' started by sama3505, Jun 19, 2016.
  1. sama3505
    Jun 10, 2016
    18
    For the circuit shoen with R1=R2=R3=330 Ohms ,V1=V2=5V .What is the volatage at D1 when the switch is closed?Use correct units and give your answer to 2 SF?
  2. sama3505
    Jun 10, 2016
    18
    I tried using kvl on V1=R1+R3 to find the I,current
  3. Dodgydave
    Jun 22, 2012
    5,143
    768
    At switch on D2 is 2.5V, the resistors are making a voltage divider across the battery. D1will also be 2.5v when the switch is pressed.
  4. jpanhalt
    Jan 18, 2008
    5,699
    909
    If the schematic is redrawn like this:
    And assuming D1 is the voltage after the switch has been closed (i.e., my interpretation of "when the switch is closed"), do you still get the same answer? That is, can D1 be calculated considering R1||R2?
    John
  5. dannyf
    Sep 13, 2015
    2,196
    417
    get the thevenin equivalent for R2/R3+V2.
    and you are done.
  6. DGElder
    Member
    Apr 3, 2016
    347
    87
    "I tried using kvl on V1=R1+R3 to find the I,current"
    How can ohms + ohms = volts?
    You can of course solve this with KVL or KCL analysis, but I suspect due to the simplicity and the symmetry of the circuit the author is expecting you to reason out a simpler solution, virtually by inspection. You could use superposition for example. Just figure the voltage division of V1 due to R1 in series with R2||R3, then double it since the other source, V2, will produce the same result. Due to the principle of superposition you just add it to the first result -effectively doubling it.
    Alternatively, looking at the node D2 it is apparent that the current through R3 must be twice the current through R1 and R2. Since the IR voltage drops must add up to 5V you can easily see what the voltage must be across R3.
    In both cases you don't even need to know the resistance values, just that they are all the same.
    Clue: the answer is not 2.5V
  7. shteii01
    Feb 19, 2010
    3,500
    511
    Show you work.
  8. WBahn
    Mar 31, 2012
    18,085
    4,917
    We can't figure out what you are did wrong unless you show us what you did. Having said that, the statement V1=R1+R3 is nonsensical as it equated a voltage to a resistance. Also, when you say that you did it to find the I, you give no indication what I is. Is it the current in the flowing to the right in R1? The current flowing upward in R2? The current in the Euphrates River? You need to clearly define the terms you use.
  9. sama3505
    Jun 10, 2016
    18
    correct answer should be 3.3v it is a multiple choice question
  10. WBahn
    Mar 31, 2012
    18,085
    4,917
    Wonderful. But I'm assuming that YOU didn't get 3.3 V (otherwise you wouldn't have started this thread). Well, how can we possibly tell why you are getting the wrong answer when you won't show us how you got the answer you did (or even what the answer was that you got)?
    BTW: Yes, the correct answer is 3.3 V for the voltage at D2 when the switch is closed.
  11. dannyf
    Sep 13, 2015
    2,196
    417
    Using the approach I outlined earlier: 5v -> 330R -> 330R//330R -> 330R/(330R+330R)*5v.
    So the current is (5v-2.5v)/(330R+330R/2) -> 5ma.
    So the answer is 5v-330R*5ma=3.3v.
    sama3505 likes this.
  12. sama3505
    Jun 10, 2016
    18
    thanks i think this is right way to do
  13. DGElder
    Member
    Apr 3, 2016
    347
    87
    V3, the voltage across R3, is the result of the voltage division by the network R1 in series with the parallel combination of R2 and R3 from the left hand voltage source. And, additionally, the voltage division of the right hand source via R2 in series with parallel combination of R1 and R3. Since R1=R2=R3, I call each R. Due to the symmetry of the circuit the voltage division of the right hand or left hand source produces the same value, so we just double the result from either case to get V3 (principle of superposition).
    so setting up the voltage divider times 2....
    V3 = 2 * 5V * [ (R||R) / (R + R||R) ]
    now divide the numerator and denominator by R to simplify the calculations.
    V3 = 10V * [ (1||1) / (1+1||1) ]
    plug in the formula for parallel combinations, 1||1 = (1*1) / (1+1).
    V3 = 10V * [ (1/2) / ( 1 + 1/2) ]
    V3 = 10V * [ (1/2) / (3/2)]
    V3 = 10V * [1/3]
    V3 = 3.33 V
  14. ScottWang
    Aug 23, 2012
    4,925
    777
    Is this your homework or the TS?
  15. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
