How to calculate the voltage across the inductor in a DC RL circuit at a time constant t=0?
Discussion in 'Homework Help' started by pavan_maddi, Feb 3, 2016.
  1. pavan_maddi
    Feb 3, 2016
    Let us consider a DC RL circuit with time constant t. Now when the time constant t=0 and how should we find the voltage across the inductor
  2. dl324
    Distinguished Member
    Mar 30, 2015
    3,375
    651
    Is this homework?
  3. pavan_maddi
    Feb 3, 2016
    No sir it was a concept given in a book. But i didnot understand this. Because he just given this in a shortcut form.
  4. ErnieM
    Apr 24, 2011
    7,434
    1,625
    One must first ask what was happening at time = t0- or the instant before you ask.
    If at t0 a switch is thrown to complete the circuit then you know the current before: simply zero. Then as the current in an inductor cannot change instantaneously you know the inductor current is zero, also the resistor current is also zero.
    Ohms law tells you the voltage across the resistor is zero, hence the source voltage is completely across the inductor.
