how to calculate the source resistance of function gen?
Discussion in 'General Electronics Chat' started by simpsonss, Mar 17, 2011.
  1. simpsonss
    Thread Starter Active Member
    Jul 8, 2008
    173
    hi,
    I have an function generator and now i'm working on the basic BJT amplifiers. But in the calculation i need the source resistance of the function generator. Does anyone know how to measure or calculate the source resistance of the function generator?
    thanks you.
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
    Measure the output without a load, measure the output with a known load. You have a voltage divider equation.
  3. jt6245
    Member
    Feb 18, 2011
    21
    Same as above BIlll mention. When the output voltage droped half of its voltage,then the loaded resistor is equal to the output resistance of generator.
  4. nomurphy
    Aug 8, 2005
    567
    12
    Quality generators are designed to drive 50 ohms, which is why it is necessary to halve the output voltage setting/reading when driving much higher (>> 50 ohms) loads.
