How to calculate the inductance (Henry) of a AWG 21 wire?
Discussion in 'Homework Help' started by electrogirl, Apr 4, 2011.
  1. electrogirl
    May 2, 2010
    47
    Given:
    AWG 21 wire
    Turns = 11
    Diameter = 1 inch
    I think this can be solved if only I knew the relative permeability of the of the core.
  2. steveb
    Jul 3, 2008
    2,433
    469
    Here is a formula and inductance calculator. Note that relative permeability is 1 because your conductor is likely copper or aluminum which are not significantly magnetic materials.
    http://www.consultrsr.com/resources/eis/induct5.htm
    Note, you can do a google search on "Inductance of a straight wire" and get more links. There may be some slight differences in the formulas, but you can try different variants to make sure you are getting a consistent answer.
