The below have two kinds of circuits, used one bjt and two bjts.
If you have different voltage to input then you need to using different resistor, 3.3K for 14V and 1.075K for 5V, you can try 1k and 1.2K.
The first you can measure the current of relay how much current is it drawn.
View attachment 80628[/QUOTE
I just confused for two ckt. If I want to use different voltage, I need to make different ckt. Did you mean like this?
For my ckt, when the voltage is reach 14V, I want the LED is off and when the voltage reach 5V LED is on. I use PV panel like photoresistor.
The problem is when I test this ckt only 2 LED light, the relay is work well(even I don't know the what value of resistor should be in there)
but I draw 2A from this ckt, relay is making sound continuously and LED light is dim.
