How to calculate origonal voltage when using DBT?
Discussion in 'General Electronics Chat' started by redrooster01, Aug 26, 2015.
  1. redrooster01
    Jul 15, 2014
    84
    I have an arcing problem in the high voltage power circuit in my Protek 6502 oscilloscope.It doesnt arc when I use my dim bulb tester though so I made up a 1.100 high voltage probe to connect to my DMM. The voltage is supposed to be neg dc -1900v, with the DBT in series I get around -1470v.Ive searched around but I cant find how much voltage drop the DBT causes and what the right voltage would be? Any help would be appreciated.
  2. #12
    Nov 30, 2010
    16,704
    7,354
    First, do you have the schematic? Owner's Manual, Operators Manual, anything for documentation?
    Second, What is a "dim bulb tester"?
    Third, What is a 1.100 high voltage probe?
  3. shortbus
    Sep 30, 2009
    4,096
    1,692
    "dim bulb tester?" Neon test light?
    "1.100 high voltage probe?" 1:100 ratio lead?
