How to calculate Load Regulation
Discussion in 'Homework Help' started by jegues, Mar 17, 2011.
  1. jegues
    Sep 13, 2010
    735
    43
    How would I go about calculating the Load Regulation in this circuit? Note that we don't know the value of RL.
    After doing some wiki'ing, I have to find the Voltage(Full Load), where IL = 20mA, and Voltage(Min. Load), where IL = 0mA.
    I have done this correctly?
    Also if I calculate a load regulation of 84% does that mean that the output changes by 84% or that it regulates 84% of the output?
    See figure attached for my attempt and question statement.
    EDIT: Also, for part e), how do I calculate the maxmimum power dissipation if I've solved for the maximum current?
  2. jegues
    Sep 13, 2010
    735
    43
    I'm pretty what I've got in my OP is incorrect.
    Here's my 2nd shot at it. Am I on the right track?
    What would IL be for no load? Is it modeled as a short circuit or an open circuit? If I know this I can find IL.
    Also, what do they mean by full load condition?
    Thanks again!
  3. Jony130
    Feb 17, 2009
    3,990
    1,115
    No load = 0A for lad current.
    All current provides provided by R flow through Zener diode
    load current is equal 20mA.
    R = (15V - 9.825V)/ ( 25mA ) - 7Ω = 200Ω
    ΔVo = rz/(rz+R) * ΔVs = ± 169mV
    Output impedance is equal
    Rout = R||rz = 6.7632Ω ≈ 7Ω
    Load regulation
    ΔVo = Rout*ΔIL = -135mV
    ---> ΔVo/ΔIL = - 6.7632mV per 1mA of load current.
    Max diode Zener current
    Iz_max = (25V - 9.825V) / (200Ω + 7Ω) = 73.3mA
  4. jegues
    Sep 13, 2010
    735
    43
    Thank you this is much more clear, however I don't think we are expected to recalculate the value of R each time, we just kept it at 205ohms as assumed.
