how to calculate boost converter element parameters ?
Discussion in 'Power Electronics' started by kittoo, Oct 16, 2016.
  1. kittoo
    Jul 11, 2016
    26
    how to calculate inductor & capacitor values in boost converter for input voltage = 325 v & output voltage = 400v (discontinuous mode)
  2. kubeek
    Sep 20, 2005
    4,691
    806
    Why discontinuous? And what sort of current do you expect on the output?
  3. kittoo
    Jul 11, 2016
    26
    output current is given to the battery,so it should be better for battery charging.
  4. DickCappels
    Aug 21, 2008
    2,777
    674
    How much output current is needed?
  5. kittoo
    Jul 11, 2016
    26
    Thanks for your reply sir,i got the answer.
    I tested with a resistor (1.2 ohms) in place of battery spec's (36v, 300ah , c10) .
    Now i need to connect a battery to the converter to charge it with 30A constant current mode but the resistance of the lead acid battery will be in milliohms. how to charge it ? if i connected a battery.
  6. BobTPH
    Jun 5, 2013
    807
    121
    You want to boost 320V to 400V to charge a 36V battery? Explain how you determined that.
    Bob
  7. kittoo
    Jul 11, 2016
    26
    Thanks for the reply,
    i am drawing voltage from the mains and that is connected to single-phase rectifier. so make the power factor unity i am using boost conv instead of smoothing capacitor,not for purpose of boosting the voltage. After boosting i will step-down the voltage with high frequency transformer.
