How to calculate and sketch transfer characteristic of this BJT circuit?
Discussion in 'Homework Help' started by xxxyyyba, Mar 18, 2016.
  1. xxxyyyba
    Aug 7, 2012
    249
    Here is my task:
    Calculate and sketch transfer characteristic for circuit below, for 0 < Vin < Vcc. It is known Vcc = 2.1V, VBE = 0.7V (when BJT conducts), VD = 0.7V (when diode conducts), VCES = 0.2V, Beta - > infinity, R1 = R2.
    Here are my thoughts. It is not possible for BJT to be in saturation and diode to conduct because VCES = 0.2V and VD = 0.7V, so KVL is not met in that case. When BJT is in forward active mode, IC = IE and IB = 0 because of Beta - > Infinity. Here are cases I analysed:
    1. BJT is in cut-off mode, diode conducts:
    2. BJT in saturation, Diode is off
    I can calculate now Ib (using KCL for BJT), but I'm not sure how to find range for input voltage Vin in this case. How to do this?
    3. BJT in forward-active, Diode conducts
    I got Vin = const in this case.
  2. Jony130
    Feb 17, 2009
    3,990
    1,115
    In what condition the diode will be if Vd < 0.7V (0.699(9)V)
    xxxyyyba likes this.
  3. xxxyyyba
    Aug 7, 2012
    249
    Diode will not conduct :)
    Related to case 2, If I prove that for some range of input voltage BJT is saturated, I also proved that in that range Diode is off, right?
  4. Jony130
    Feb 17, 2009
    3,990
    1,115
    Ok I understand. But notice that for Vce <0.7V diode is OFF but the BJT is not yet in saturation.
  5. xxxyyyba
    Aug 7, 2012
    249
    So case 2 (diode off, bjt in sat.) is not possible?
  6. Jony130
    Feb 17, 2009
    3,990
    1,115
    No, all I want to say is that when the BJT is turns ON (Vin > 1.4) and Vout = 1.4V transistor already will be in active region.
    And with your strange boundary for the diode lead me to the conclusion that the diode must immediately turn off after the BJT is ON.
    But this is not going to happen in real world.
