How To Calculate A Base5 Multiplication...
Discussion in 'Homework Help' started by transgalactic, May 9, 2008.
  1. transgalactic
    Thread Starter Active Member
    Apr 29, 2008
    74
    i have two 3 bit numbers and i need to calculate their resolt in base 5
    how to do that???
  2. mentaaal
    Oct 17, 2005
    451
  3. mentaaal
    Oct 17, 2005
    451
    I'll give you a hint, how do you multiply in decimal by long hand?
    Think carefully as to what you are doing and apply it to your problem, EXACTLY the same rules apply, you will see that from the links i have sent your, the rules of maths still apply to any counting system.
    This is an example, of a base 5 multiplication,
    344
    * 2
    1243
    Try and figure out whats going on here whithout me telling you.
