How to build a delay circuit?
Discussion in 'General Electronics Chat' started by dbroadberry, Oct 25, 2010.
  1. dbroadberry
    Oct 25, 2010
    I'm a final year physics student and as part of my final year project I need a circuit that can provide me with two sine waves ∏/2 out of phase with equal maximum/minimum.
    I will be using a signal generator to provide me with a steady sine wave input with constant magnitude but varying frequency.
    My knowledge of electronics is very basic but I imagine I need something like a two branch circuit that has a capacitor in one branch and another branch that allows the input signal to pass through unchanged.
    Basically I need two output signals ∏/2 out of phase from a single input signal.
    Can anybody help?
    Dan
  2. Ron H
    Apr 14, 2005
    7,050
    657
    It is very difficult to do with purely analog circuits, unless you generate the signals with a quadrature oscillator instead of a signal generator with a single output.
    What is your frequency range?
  3. atferrari
    Jan 6, 2004
    2,663
    784
  4. dbroadberry
    Oct 25, 2010
    Thanks for the replies. I'm not 100% certain of my frequency range yet as it will depend on the physical geometry of the system for which the circuit is going to be used to control (a linear synchronous motor) but I imagine it will be between 0 and 100Hz.
    That document seems to be quite detailed but also suggest that I'm going to have issues with the output voltages as I vary the frequency of the input. I really need to have a constant voltage across all the frequencies I use.
    It occurred to me earlier that I may be over complicating the situation. As the 1st derivative of sine is cosine, is that a circuit that essentially take the derivative of an input signal?
  5. Ron H
    Apr 14, 2005
    7,050
    657
    The derivative of sine(ωt) is ωcos(ωt), i.e., the amplitude rises linearly as a function of frequency.:(
  6. Ron H
    Apr 14, 2005
    7,050
    657
  7. Ron H
    Apr 14, 2005
    7,050
    657
    As Agustin suggested, the best solution is probably DDS (direct digital synthesis), but it is not simple for a novice.
  8. atferrari
    Jan 6, 2004
    2,663
    784
    Yes, it seems that THAT could be a problem.
