How to build a bench top Spark Plug tester
Discussion in 'The Projects Forum' started by Gdrumm, Oct 19, 2013.
  1. Gdrumm
    Thread Starter Distinguished Member
    Aug 29, 2008
    684
    36
    I've got a bunch of old lawnmower spark plugs I would like to test.
    I saw bits of a Youtube video in Russian, that shows one, with a coil and some other components I couldn't reccognize.
    Any thoughts on how I could make one?
    I have boxes full of electronic components I've saved.
    Surely there is an easy way to make one.
    Any ideas?
    Searches on Google just produces a million or so ads for spark plugs.
    Thanks,
    Gary
  2. MaxHeadRoom
    Jul 18, 2013
    10,832
    2,502
    Pick up an old style ignition coil and a distributor from a wrecker get an old single cyclinder cycl head from a mower etc to screw the plug into, and you have all the makings for probably less than $10.00.
    Not elegant electronics, but would work.
    Or a 555 and a Mosfet in the primary of the coil, if you want the elegant way?
    Max.
  3. Gdrumm
    Aug 29, 2008
    684
    36
    Thanks Max,
    Gets me thinking.
    I have an old chainsaw that doesn't work, but has spark.
    It has no bar or chain either.
    I can remove the recoil and use a socket and drill to rig it for easy turnover, then connect the wire, and lay the sparkplug against the head, and give it a go.
    That should work.
    Gary
  4. MaxHeadRoom
    Jul 18, 2013
    10,832
    2,502
    There you go! ;)
    Also you could get a piece of Aluminum plate and get it drilled and tapped with the 2 most popular sizes, 14mm 18mm ??
    And bolt the plate to the head or a bolt on the casting.
    Max.
  5. Gdrumm
    Aug 29, 2008
    684
    36
    The old chain saw idea worked great.
    I went through a dozen old spark plugs, and found that 1/2 of them were good.
    It wasn't rocket science ..... oops; ...surgery.
    But it was Chain Saw Surgery, and that sounds scary here at Halloween.
    Thanks,
    Gary
  6. shteii01
    Feb 19, 2010
    3,500
    511
    Just for the record... How many rolls of duct tape were used?
  7. wayneh
    Sep 9, 2010
    12,374
    3,226
    Haha, old chainsaw as lab bench instrument. Gotta love it.
  8. pilko
    Dec 8, 2008
    213
    20
    I use a peizo push-button igniter salvaged from an old BBQ. It produces a healthy spark on a good plug.
  9. shortbus
    Sep 30, 2009
    4,088
    1,670
    The only thing with all of this is, when a plug is under cylinder compression it may not fire, when it will at atmospheric pressure. Why were the plugs removed from the motors? Probably cause they didn't work.:)
