how to amplify
Discussion in 'The Projects Forum' started by aridass, Jan 29, 2013.
  1. aridass
    Jan 15, 2013
    5
    hai there..i need some help for my project.. im doin a project using load cell and my load cell produce mV signal.. how to amplify the signal and i wan to make it instrumentation standard signal 1-5V. please help me.
  2. MrChips
    Oct 2, 2009
    12,622
    3,451
    Usually a load cell is a Wheatstone bridge and requires an instrumentation amplifier.
    Did you google load cell amplifier?
  3. Salaja
    Jan 27, 2013
    23
    would an op-amp work?
    cheap ones can have bias voltages of a few mV, so the output signal wouldn't be perfectly accurate, but it should still amplify it reasonably well.
    to get it between 1v and 5v, you may also need to use an op-amp to 'add' it to a voltage offset (or just use a voltage divider, whatever).
  4. aridass
    Jan 15, 2013
    5
    i will search bout it in google..tq mr. chips
