How to amplify an AC signal
simeonz11
Joined Apr 29, 2008
98
I wish to amplify a small AC signal to a big power signal .
I'm using this op amp made for hv operations , it says its made for hv . itr has a maximum current of 50mA .
http://focus.ti.com/docs/prod/folders/print/opa445.html
This is my circuit , the goal here is to power a transformer with this AC signal , using only batteries . I know emitter-follower , thats easy on its own , but This is an AC follower emitter so I just cant figure it out by myself now .
I usually try to figure things out on my own , but for this I am just stuck . I dont wanna spent any $ on testing and I dont have a sim .
I just need a good schematic to amplify this signal , the "whats next" .
I think alot of people would also like to know this .
bertus
Joined Apr 5, 2008
22,276
How much current do you need?
The OPA445 can deliver 15 mA.
There are others mentioned on the page:
See Also
  • OPA452 - 80V supply with 50mA continuous output instead of 90V, 15mA.
  • OPA551 - 60V supply with 200mA continuous output instead of 90V, 15mA
Greetings,
Bertus
simeonz11
Joined Apr 29, 2008
98
Thx Bertus .
Well I am currently using a tl082 for my testing pusposes , it is a fet input .
Whats the difference with a fet input and another I dont know , I know this one and like it .
Do I have to add or change anything with the other ? I'll use the 200 or 50 if its the same exact thing .
I purchased a high dollar high current lm675 from DIGIKEY buy that piece of crap messed up my input signal , can you imagine that lol ? I tought it was the other way around , the inpout signal has an effect on the output, not the other away around !!!!!!!! Its just a load of trouble to get it goin right .
I was gonna need a transistor stage anyways .
So Now i'm using a high voltage lower current less $ with an emitter followr stage . at leats I'm trying to
bertus
Joined Apr 5, 2008
22,276
What frequency do you want to amplify?
How many gain do you need?
The OPA551 and OPA 552 will work upto ± 30 Volts.
Greetings,
Bertus
simeonz11
Joined Apr 29, 2008
98
anywhere from 50 to 15000 hz
I dont know how much current , enough to make my emitter follower where I= V/Rload
just that really , I want to mimic my wave and provide current based on whatever load I have ...
Nothing more than 4-5 amps .
bertus
Joined Apr 5, 2008
22,276
What will be the load?
In what resistance range will the load be?
It sounds like an audio amplifier to me.
Greetings,
Bertus
simeonz11
Joined Apr 29, 2008
98
Hi bertus
Nothing below 20 ohms , not too much power .
Its for a "special" science project .
bertus
Joined Apr 5, 2008
22,276
When you say 5 A and 20 Ohms the power will be ( P = I X I X R ) = 5 X 5 X 20 = 500 Watts.
For 5 A in 20 Ohms you will also need ( U = I X R ) = 5 X 20 = 100 Volts to get it.
This is quite a power.
If the resistance is even higher the power will rise too.
Greetings,
Bertus
simeonz11
Joined Apr 29, 2008
98
Hi Bertus.
That would be in the worst case scenario .
The resistance will be higher than 20 ohms .
I will never reach anything close to 500 watts load . Maybe not even 100 .
That would be defeating the purpose of my special project .
I am not worried about maximums here .
bertus
Joined Apr 5, 2008
22,276
What will be the maximum load resistance?
You say it is higher than 20 Ohms, but not how high.
I think the current will not be higher than about 2 A.
Take a look at the attached PDF about voltage to current converters.
Greetings,
Bertus
simeonz11
Joined Apr 29, 2008
98
Hi bertus,
Like I said , it all depends on the resistance of whats on my secondary side , it all depends .
I dont have any solid numbers but the goal here is to go for low amps .
Thx for that pdf , that howlad bidirectionnal current source looks good for my application , do you think so ??
simeonz11
Joined Apr 29, 2008
98
Ok I have identified 2 possible working circuit .
I need your opinion .
My goal is to run a transformer remember and immitate the wall plug only higher frequency.
I wanna know whats the difference between these 2 , what dooes the "current sense" do anyways ?
There is not much info on this bidirectionnal current sense .
is this needed at all , wich one of these would be best for my application , I have no idea about that Rsense thing
Also , wouldnt the transistors need diodes before them to protect them from reverse voltage ??
Theres gonna need a base resistor also ...
