How to add sin voltages
Discussion in 'Math' started by Twitchr, Nov 1, 2009.
  1. Twitchr
    Oct 31, 2009
    5
    Hey guys,
    I'm having some trouble with an assignment. I need to add a couple of sin voltages, and am having trouble finding out how to do so.
    So just for example, if I wanted to add 12sin(3t-25degrees) + 17sin(5t-40degrees)
    I have searched the forums and haven't found a similar topic, But i do apologize if this is a repost of some other thread.
  2. hgmjr
    Jan 28, 2005
    9,030
    214
    Have you thought about putting the equations into EXCEL?
    hgmjr
  3. studiot
    Nov 9, 2007
    5,005
    515
    You need the transformation
    sin A + sin B = 2 sin 0.5(A + B) cos 0.5 (A - B)
    followed by a bit of algebraic/trigonometric manipulation to simplify.
  4. Twitchr
    Oct 31, 2009
    5
    Thnx for your help, really appreciated.
  5. Twitchr
    Oct 31, 2009
    5
    I tried got a little stumped on it again, What do I do with the 12 and 17?
    And for the A and B, for A+B would I just do (3t+5t)+(-25-40) to equal 8t-55?
    btw, when I entered it into excel it gave me error.
  6. Twitchr
    Oct 31, 2009
    5
    Just to make sure, would the answer to my equation would be
    204Sin(4t-75degrees)Cos(1t+15deegrees)?
    I would hope that you dont half the phase angle, but correct me if Im wrong.
  7. t_n_k
    Mar 6, 2009
    5,448
    783
    Doesn't look correct. Perhaps you could show your derivation.
    As far as using excel you would just set up column A for the time variable - say from 0 to 7 seconds with a step size of say .05 sec. I'd assume you'd put a heading in row 1 and data would be in row2 onwards
    Then type the equation in the first column B data cell (i.e. starting at B2) in the form
    =12*sin(3*A2-25*pi()/180)+17*sin(5*A2-40*pi()/180)
    then copy down the column to the end of the time data in column A. If you create a similar column for your derived function and plot the data for both cases you'll see something is wrong.
  8. Thav
    Member
    Oct 13, 2009
    82
    I've actually been looking at this type of problem at work. As far as I can tell the identity studiot posted does not take into account the coefficients 12 and 17. This link should have some information to help you, but it may not be the method your instructor intended.
    http://scipp.ucsc.edu/~haber/ph5B/addsine.pdf
  9. someonesdad
    Jul 7, 2009
    1,585
    141
    I'd like to reword the OP's question as:
    Does anyone know if there's a closed-form expression for
    (1) sin x + a sin y
    where a, x, and y are real numbers that is similar in form to
    (2) sin x + sin y = 2 sin {\frac {x+y}{2}} cos{\frac{x-y}{2} ?
    I did a little work looking through some handbooks (CRC Math Tables, Gradshteyn and Ryzhik, "Tables of Integrals, Series, and Products") and looked at Wolfram's Mathworld, but failed to find anything relevant. I also did some numerical experimentation to get a feel for the behavior of the equation for a few choices of the parameters.
    The reason it would be nice is that formula 2 shows you that the addition of two sinusoids with different frequencies will result in a sinusoid with a frequency that is the difference of the two frequencies (the "beat" frequency) and modulated by a sinusoid that is the sum of the two frequencies. A formula for 1 should reduce to 2 when a = 1.
    We've been adding sinusoids for hundreds of years and I expect if there was a relatively simple closed form formula for 1, it would be in the math handbooks. But it never hurts asking... :)
  10. studiot
    Nov 9, 2007
    5,005
    515
    I have to admit I rushed and didn't see the coefficients.
    If you expand AsinB in a series and sinC in another similar series you can add term by term to get
    AsinB + sinC = { (AB+C) - (AB^3+C^3)/3! + (AB^5+C^5)/3! - (AB^7+C^7)/7!.....}
  11. Thav
    Member
    Oct 13, 2009
    82
    Someonesdad, your equation 2 is what 've been after and have yet to find a nice solution.
  12. KL7AJ
    Nov 4, 2008
    2,043
    292
    Why not just resolve each value first and then add? This is what makes the superposition theorem so super!
    eric
  13. Twitchr
    Oct 31, 2009
    5
    Thanks for all your help, I found out in class that I was taking this too far, I read the question correctly, however the prof only wanted us to put a plus sign between the two. Hopefully I will get extra credit for this.
    I even brought this up to my buddy who is a physics major, and he had no clue what to do, however his friend, who is a music theory major helped me to get it. He gave me the same formula as someonesdad
    Thanks for your help
  14. ispymalik
    Member
    Apr 7, 2008
    18
    change it to complex exponential's? do simple algebra then go back to sin's and cos's.
