How to activate Relay?
KMoffett
Joined Dec 19, 2007
2,918
What is the part number on your relay? Is it a 5V?...12V?...24?
Do you want the relay to be activated with a high out of the NAND gate or a low?
Ken
jj_alukkas
Joined Jan 8, 2009
753
Use an NPN transistor like BC337, BC548, SL100 and connect as follows.
Emitter to GND
Base to NAND output through 1-10k resistor depending upon supply voltage.
Collector to relay terminal
2nd terminal of relay to +12
Also dont forget a reversely connected protection diode across the relay.
What is your supply voltage? For 12v, use a 12volt 200 ohm relay. No of poles depends on your application.
The above connections are for a high out which is what you need I guess. For a low out, Use a PNP and reverse connections.
