Actually my aim is to amplify the PD across the LED terminals currently its just 0.1 V!Hello,
The mobile bug you show in the link is never drawing 5 A.
Can you give us more info.
With the info provided we can not do anything.
Bertus
PD? As in photo diode? If it is how does it apply with this?Actually my aim is to amplify the PD across the LED terminals currently its just 0.1 V!
http://www.physicsforums.com/showthread.php?p=2853797
Yes it is DC voltage but 10 time higher will not help 50 times is required !!A simple op amp such as the LM358 can amplify a small voltage like that, just set the gain to 10. Since your talking LEDs I am assuming DC voltage.
Here the circuit uses a 0.22µF disk
capacitor (C3) to capture the RF signals
from the mobile phone. The lead length
of the capacitor is fixed as 18 mm with
a spacing of 8 mm between the leads to
get the desired frequency. The disk ca-
pacitor along with the leads acts as a
small gigahertz loop antenna to collect
the RF signals from the mobile phone.
This is a blast from the past! Just after the Korean War, lots of military components went on the surplus market. A man who styled himself "Madman Muntz" started putting out a line of very cheap TV's using surplus parts.Here the circuit uses a 0.22µF disk
