How to a activate a MP3 trigger from a switched AC outlet
Discussion in 'General Electronics Chat' started by Pylass, Mar 19, 2016.
  1. Pylass
    Mar 19, 2016
    What ac to dc switch would be needed to activate an MP3 Trigger?
    The MP3 trigger plays audio tracts. It has a trigger sensor (3.3-5.0vdc) that triggers audio tracts to play.
    When I turn on a switched outlet (120vac), i would like the ac to dc switch to send a signal to the MP3 Trigger.
    I will also have an LED light box (I believe its 10 or 20 watts) connected to this switched outlet.
    The MP3 Trigger is found below.
    Thank you Members
    Pylass
    https://www.sparkfun.com/products/13720
  2. blocco a spirale
    Jun 18, 2008
    1,460
    370
    It says the input is active low with internal pull-up. The easiest way is to use a 120 VAC relay to close a contact to pull the input low.
  3. Pylass
    Mar 19, 2016
    Is there a specific 120VAC relay that you recommend?
  4. blocco a spirale
    Jun 18, 2008
    1,460
    370
    Pylass likes this.
  5. AnalogKid
    Distinguished Member
    Aug 1, 2013
    4,687
    1,297
    The smallest, lowest power thing you have access to. It must be an electromechanical relay; a solid state relay will not work in this applicatin.
    ak
