How ti use timer in PIC16F877A
Discussion in 'Programmer's Corner' started by phyllis, Apr 25, 2015.
  1. phyllis
    Apr 25, 2015
    I am doing noise detector project using PIC16F877A. How to turn on led if people make noise more then 1 minute?
  2. jpanhalt
    Jan 18, 2008
    5,699
    909
    What programming language? At what frequency are your operating the MCU? How do you detect the noise?
    John
  3. atferrari
    Jan 6, 2004
    2,663
    784
    Does it mean that if you detect noise for only say, 54 seconds, your count will reset to zero and no LED will be turned ON?
  4. Papabravo
    Feb 24, 2006
    10,340
    1,850
    How to use the timer in PIC16F877A
    1. Download the datasheet
    2. Assume a comfortable position
    3. Study the datasheet with intense concentration
    4. When you grok the use of the timer, proceed
  5. MaxHeadRoom
    Jul 18, 2013
    10,836
    2,509
    One avenue to explore is using a clock crystal (32Khz) on the T1CKI input which can be used for seconds,minutes, hours clock.
    In conjunction with a capture input using the CCP module. In your case the timer would be constantly reset if and when noise occurs, if none for 1 minute, it allows the clock to time out.
    i.e. an interrupt would occur at the 1 min mark.
    Max.
  6. John P
    Oct 14, 2008
    1,638
    225
    Or as Bill Haley and the Comets would tell you, the objective is to "Grok around the clock".
