Actually, the ADJ pin current flows out of the pin, so it causes the output voltage to be higher than calculated, not lower.The 50uA to 100uA current for the ADJ pin reduces the output voltage about 0.15V so the actual output voltage is 24.02V (plus and minus a small tolerance).
What is 10.42?why in it use 630 ohms and not 57.1 (7..2-1.25/10.42)
by Jake Hertz
by Duane Benson
by Jake Hertz
