How should I stop 7 segment for counting? It should be only be counting 0-8.
Discussion in 'Homework Help' started by Tomomi Mei Manalili Reyes, Feb 3, 2016.
  1. Tomomi Mei Manalili Reyes
    Feb 3, 2016
    49
    It should be continuously counting, without buttons.. Please help T^T
    And what IC should I use? ill be using a cathode 7 segment.. TY
  2. dl324
    Distinguished Member
    Mar 30, 2015
    3,379
    651
    Is this homework?
  3. hp1729
    Nov 23, 2015
    2,103
    233
    You want it to count from 0 to 8 and then back to 0? Set it to reset at 9. Use any 4-bit counter.
  4. Tomomi Mei Manalili Reyes
    Feb 3, 2016
    49
    this one is my layout..
    Its not just simply a homework.. If I cant do this in PCB, our professor will give me 5...
  5. Tomomi Mei Manalili Reyes
    Feb 3, 2016
    49
    reset? how??
  6. dl324
    Mar 30, 2015
    3,379
    651
    I have requested that your post be moved to the Homework Help forum where you'll be guided to a solution.
    What is the counter doing as wired?
    What were you told to do with unused inputs?
    What purpose does the 220 ohm resistor serve?
    Will the BCD to seven segment decoder work as you have it wired?
    The bubbles on the outputs of the decoder indicate the outputs are low active. You have the common terminal on the display connected to ground. Do you think that will work?
    What were you taught about current limiting for LEDs?
  7. BillB3857
    Feb 28, 2009
    2,402
    348
    How would YOU know when the counter got to nine? What device can you think of that could generate a positive signal when it recognized nine?
    What pin(s) of the 74ls90 could you use to force the count back to zero? If you answer these, you have it made.
  8. hp1729
    Nov 23, 2015
    2,103
    233
    Good so far. So you want to reset it to zero at a count of nine?
  9. Tomomi Mei Manalili Reyes
    Feb 3, 2016
    49
    Yes.. please help.. I need this badly today.. T^T
  10. Tomomi Mei Manalili Reyes
    Feb 3, 2016
    49
    I literally dont know.. Our professor gave us this task but he didnt teach us on what should we do. He told us to have an idea through internet, but i cant find any information about it.. >o< I badly need this today. I must have a layout for this to put it on photo-pcb.
  11. BillB3857
    Feb 28, 2009
    2,402
    348
    It would be impossible to lay out a PC board without first having a working circuit design. The one you posted WILL NOT do what you want. The suggestions/questions posted are to help GUIDE you into a thought process to arrive at the answer you need to make the circuit work. This forum does not do your homework for you, but will try to help. If you would even attempt to answer questions, you may get more help. Otherwise, well........
  12. Papabravo
    Feb 24, 2006
    10,340
    1,850
    We are sorry that your professor is such an inadequate teacher, and that your university employs such incompetent people. Maybe you should ask for a refund, or better yet don't register for the next term.
  13. Tomomi Mei Manalili Reyes
    Feb 3, 2016
    49
    yeah i know. that is why i need to figure i out as early as i can so i can now proceed in pcb layout.
    will someone answer me if i ask questions?
  14. Tomomi Mei Manalili Reyes
    Feb 3, 2016
    49
    You might have point. But for me, his just one of the hard paths of my dreams. So I'll never give up on him too easily.
  15. Tomomi Mei Manalili Reyes
    Feb 3, 2016
    49
    can you explain it to me what is the function of 74ls90? Q0-Q3 are connections to A-D. CKA is the positive or power voltage.. Then what is the function of CKB and R0-R9?? O.O Does connections from Q0 and 7 to CKB is the reason why it counts to 9??
  16. dl324
    Mar 30, 2015
    3,379
    651
    Start by answering the questions you've been asked. Don't expect anyone to simply give you answers because you're short on time. We've seen students in that situation numerous times.
    Given the amount of time you have, it's unlikely that you'll be able to complete a PCB layout. Doing that without having a working circuit is pointless.
  17. dl324
    Mar 30, 2015
    3,379
    651
    Have you read the datasheet?
  18. Tomomi Mei Manalili Reyes
    Feb 3, 2016
    49
    not yet... O.O
  19. dl324
    Mar 30, 2015
    3,379
    651
    How do you expect to be able to understand how to use the counter if you don't know how it works?
    How did you determine that QA needed to be connected to CLKB?
  20. Tomomi Mei Manalili Reyes
    Feb 3, 2016
    49
    QA and CLKB must connect for the loop..?
