This 3phase rectifier connected to 2 capacitors and we use r1 to make the center between 2 capacitor is very close to ground voltage =0 v so can someone help me to understand how this happen
is used as input for buck converterthe circuit makes little sense. What is it's purpose?
Well you can't get that from your posted circuit.is used as input for buck converter
I too caught the bridge isn't right... but it actually should work. OP has 12 diodes instead of the traditional 6, but the extra's are in parallel with the ones required so it is good.Well you can't get that from your posted circuit.
For a three phase bridge rectifier you only need 6 diodes (see the bottom of this page).
by Aaron Carman
by Duane Benson
by Jake Hertz
