how r/f time effects on EMC in IC's design in PCB?
Discussion in 'General Electronics Chat' started by knrdeepak, Jun 12, 2009.
  1. knrdeepak
    May 21, 2009
    5
    hello guys.. im new to this blog,
    Please give me the information on relation between rise time, fall time in signal spectra(IC's on PCB) with EMI and RFI.
    how could effect r/f times to EMC of IC's in PCB design?
    I will be thankfull if any1 upload this here..
  2. R!f@@
    Apr 2, 2009
    8,789
    771
    Rise time and fall time effects only in high frequancies, were PCB tracks introduce stray capacitance.
    In lower frequencies this is not much of a problem.
    It counts when you want high speed digital's
    You have to be more specific.
    ______________
    Rifaa
  3. knrdeepak
    May 21, 2009
    5
    Thanks for your reply...
    could you please explain how these High frequency(more than 1gb processors) can introduce stray capacitance and indirectly to PCB...is there any theory(or formula) behind it to understand above scenario...Please giv a reply...
  4. mik3
    Feb 4, 2008
    4,846
    63
    Any pair of conductors separated by a dielectric forms a capacitor. On PCB the tracks are separated by the insulating material of the PCB and air. This caused stray capacitance which cause problems in high frequency systems if they are not designed properly.
    It is hard to analyze this stray capacitance and there is not a standard formula to calculate it.
    You can study transmission lines theory if you want to learn more about it.
    Note that there is also stray inductance in the circuits.
