how PNP Transistors and batteries work
jordanwb
Joined Jun 22, 2008
30
Hello again. I have two questions.
1: I understand the operation of NPN transistors, but how do PNP work? Is it if power is flowing away from the base of the transistor, it allows power to flow from the collector to the emitter? I found this page, I understood the part about PNPs being oppisite of NPN transistors, then nothing made any sense after that.
2: This question is a bit of an addition to the dude's question in this thread. If a light is connected to a battery and the battery can produce 1 amp of power at 6 volts, and the light draws 0.5 amps of power; does 0.5 amps of current flow out of the battery or does 1 amp flow out and 0.5 amps flow back into the battery?
SgtWookie
Joined Jul 17, 2007
22,230
They're nearly exactly the same as NPN's, except complete opposites. Confusing initally, to be sure.
When I was a teen, I was given a Norelco kit for building circuits. They were primarily PNP transistor circuits. I had a hard time accepting NPN transistors when I was later introduced to them. They seemed so upside-downish and improper from what I'd learned.
Only 0.5A flows out of the battery. There is no "flowing out, and flowing in". In DC circuits, there is no reverse electron flow. If there were, it would be an AC circuit.
beenthere
Joined Apr 20, 2004
15,819
As another illustration, a PNP transistor can be substituted for an NPN in a simple circuit. Reverse the battery connections, and the circuit operation will be the same.
Audioguru
Joined Dec 20, 2007
11,248
So for PNP if the base is connected to ground, it will allow power to travel from emitter to collector?
If the base is connected to ground then an extremely high current will flow in the base-emitter diode which will blow up the transistor. The base current must be limited by a series resistor. The base to emitter voltage of a turned on transistor is only about 0.7V.
jordanwb
Joined Jun 22, 2008
30
So since there's no actual case there's no need for a schematic, right? Right. Moving on. So basically a PNP transistor lets current flow from the emitter to the collector if current is flowing away from the base to ground.
Norfindel
Joined Mar 6, 2008
326
The emitter and base form a junction that works like a diode, if you have the emitter directly connected to the supply (+), and the base to ground (-), then you need a resistor there to limit the current, or it would be the same than putting a diode across the power supply.
With a small current flowing thru that diode, then a larger current will flow from emitter (+) to colector (-). To remember it, think about the base-emitter diode forward-biased, and the collector with the opposite polarity than the emitter. Works for me :)
