how PCB is translated onto a plastic board?
Discussion in 'General Electronics Chat' started by PG1995, Aug 30, 2011.
  1. PG1995
    Thread Starter Active Member
    Apr 15, 2011
    753
    5
  2. ian123
    Member
    Aug 24, 2011
    73
    there are several ways to do this but i find a good quality inkjet printer set to high quality and glossy photopaper to work very well.
    you need to purchase overhead projector film for inkjets and bobs your aunty print onto overhead projector film.
    make sure you get overhead projector film for inkjets its different to the one used for laser printers.
  3. mcgyvr
    Oct 15, 2009
    4,791
    976
  4. Markd77
    Sep 7, 2009
    2,803
    594
    For something that small, and if there is just one or two, I'd use an etch resist pen on single sided copper clad board, then etch.
    I use an Edding 400 permanent marker.
    The proper way is to make a transparency, then UV expose UV sensitised board using the transparency, then develop the board to remove the unwanted coating, then etch.
  5. debjit625
    Apr 17, 2010
    790
    186
  6. ErnieM
    Apr 24, 2011
    7,442
    1,628
  7. Wendy
    Mar 24, 2008
    20,772
    2,540
