How on earth do they make stuff like this?!
Peytonator
Joined Jun 30, 2008
105
Every time I see a picture like this....
... I'm totally lost for words. How on earth do they do it? How can they make for example a PIC24 for just $2.5, and it can have like a billion transistors in it?! And yet, I'm totally befuddled by the simplest of transistor circuits.
I think this is actually all fake or something :p
Wendy
Joined Mar 24, 2008
23,429
No, it's not fake. I bond gold wire that is 0.001" onto chips like that every day. That particular chip only has a few hundred transistors. When they get really dense, say a million plus transistors, they have a holographic look to them.
We use pure gold (99.99%) in my shop because it is so workable. Some of the chips use gold as the conductor, some aluminum. You can get gold to stick to aluminum with good results, but gold to gold is best, it actually gets stronger with time. Most commercial chips use aluminum wire to aluminum pads.
Looking at that part it appears to be a 3 terminal voltage regulator. Call it an educated guess.
tom66
Joined May 9, 2009
2,595
It's a conspiracy. Most chips are filled with "magic smoke"; this is what makes them work. When a chip releases the magic smoke (e.g. due to overvoltage, overloading etc.), an essential component is lost, and the chip does not work any more.
On a more serious note, you should look up photolithography.
If I remember correctly, a PIC24F has around 1 million transistors on the die.
Peytonator
Joined Jun 30, 2008
105
Wow... interesting.... I always wondered what that smoke was, when I turned the power supply on too high ;)
But how do they actually BUILD it...how do you make the transistor and connect it in the circuit. Do you use lazers or what? Because you certainly can't do it by hand :)
Have you heard about the new "3D" transistors... no longer planar in topology? Check this out:
http://spectrum.ieee.org/tech-talk/...els-new-transistors-enter-the-third-dimension
EDIT: ohhh right... photolithography
Peytonator
Joined Jun 30, 2008
105
I was actually thinking about something similar with regard to lab-on-a-chips. You basically need to make an artifical DNA sequence that matches that of a tissue sample. If it doesn't match, crosscheck with a database to see what disease the person has.
tom66
Joined May 9, 2009
2,595
Photolithography is very clever. You basically make a large set of masks - which can be printed or produced in some way, and you scale the image down really small. You etch the silicon using a complex chemical process involving light.
Wendy
Joined Mar 24, 2008
23,429
Lately, for the really dense chips, they are working on new methods. I remember reading about an X-Ray laser being used. The resolution depends on the wavelength of light, the longer wavelength can't make as small shapes. X-rays however, are very short wavelength and can make smaller shapes.
Markd77
Joined Sep 7, 2009
2,806
I saw an excellent episode of "How do they do it?" on chip manufacture. With any luck it's on youtube somewhere. If the man narrating it seems familiar, it's because he is Kryten from Red Dwarf.
Peytonator
Joined Jun 30, 2008
105
WOW... is this what you're referring to? http://www.youtube.com/watch?v=aoDgulny31M
It's so amazing what man has actually been able to do... "nothing that they propose to do will now be impossible for them" (Genesis 11:6)... as at the Tower of Babel.
It it true that the speed of light is actually too SLOW? I.e., that it creates delay problems from one side of the chip to the other? Delay problems as in 0.1 ns :D
QuadTech
Joined Apr 19, 2011
6
When you take a step back and think about it, it's more than a little awe inspiring to think that we can manufacture chips like this. Not that long ago, this kind of technology was science fiction. Actually, science fiction predicted we'd be leaving on Mars, but computers would still take up a whole room in your house.
Markd77
Joined Sep 7, 2009
2,806
Yes, that's the one. I couldn't believe the size of the single crystal silicon blob when I saw it.
And yes, light (and an electrical signal) only travels 3cm in 0.1ns so at gigahertz frequencies it has to be taken into account.
magnet18
Joined Dec 22, 2010
1,227
All this, and the number of transistors in the same space doubles every year...
Makes you wonder what it's gonna be like in a couple decades... molecular level computers aren't a stretch...
Bill, what exactly do you do?
Wendy
Joined Mar 24, 2008
23,429
I work for Raytheon in a class 1 clean room, the lowest class there is. I run very smart robots that lay wire and ribbons that bond to raw chip stock to ceramic printed circuits. The term is Microelectronics. I also use manual bonders (the machines that bond the small wires to the equally small components) and repair any damage that may have happened to the wires. If the chip is damaged I send it off to be replaced. Most chips are glued to the ceramic board with either conductive or nonconductive epoxy, depending on the design.
I used to repair these and other machines on the factory floor, I was machine maintenance for Alcatel. During the telecom crash I lost my job, and took the one at Raytheon because to repair the machines I had to know how to use them.
To be a machine maintenance tech I was a lead tech, sort of an interface between engineering and the test tech on the floor. I was the guy the test techs called when they had problems. I also spent a stint as a calibration tech (which was another lead tech position) repairing and calibrating test equipment.
Someday, if the economy ever picks up, I can get a job I'm not overqualified for. For now though, it is good to have a steady decent job.
magnet18
Joined Dec 22, 2010
1,227
Cool, I know a couple people that work at raytheon in fort wayne, don't know much about what they do though, just that one complains about wearing an anti-static lab coat every now and then.
Do they let you build any microscopic 555's? ;)
majsyd2010
Joined Aug 29, 2010
61
Good One !!!!! :)
Wendy
Joined Mar 24, 2008
23,429
Jerri Ellsworth made a homemade MOSFET just to prove she knew how. Not many people have her home lab though. This is the same lady who designed a Commodore 64 and 1541 on a chip to put a Commodore 64 gaming system on a joystick. She has done a lot more of course. Last I heard she basically freelances.
I've been in love with her for many many years. Pretty, and brains!
magnet18
Joined Dec 22, 2010
1,227
You, and about 8 million nerds...
IIRC she's married
