How much power required for H7 12v 100w Bike Halogen Bulb?
Discussion in 'The Projects Forum' started by paul.1911, Mar 25, 2012.
Thread Status:
Not open for further replies.
  1. paul.1911
    Mar 25, 2012
    33
    I am new here and I've hero honda bike thinking to use 100w bulb. I know it will not support rather than 35W/35W bulb. But I want to try. Searched a lot and found magneto does not provide enough volt, you need to rewind the coil. But the thing is magneto produce 30V to upto 40V AC. That AC is being regulated for a bulb: not to fuse, and not being convert to DC for a headlamp.
    Battery wires is separate. Rectifier is used to output 13.8VDC to charge it.
    So I thought why I can't make my own regulator rectifier dropping 30v to such that 100W head lamp glow in its full brightness. If not at least for 60W/55W.
    But I need help and found this best place to ask from you experts.
    So How much volt, watt, ampere should be there to make 100W bulb to glow in its full efficiency for long time? don't want to turn it black or fuse.
    I'll only replace stock regulator for headlamp not rectifier for battery.
    Is this possible:confused:? I think it is :p
    Please Help!!:(
  2. R!f@@
    Apr 2, 2009
    8,785
    771
    Well ! This is one place where u can do that and I too have done some thing similar. :D
    But if you try to break into the scooter harness, this thread won't survive the pressure.
    Read the Tos lately
  3. panic mode
    Oct 10, 2011
    1,328
    305
    the most basic equation for power is simply:
    P=V*I
    where
    P=power [watts]
    V=volage [volts]
    I=current [amps]
    100W is power - you already decided on that.
    and 100W is 100W regardless how you get it:
    100W=100V*1A
    = 30V*3.33A
    = 25V*4A
    = 12.5V*8A
    = 13.8V*7.25A
    = 10V*10A
    = 1000V*0.1A
    = 10000V*0.01A
    etc.
    note that size of wires is determined by current. (reason Edison lost war of currents).
    twice the current means that cross section of wire must (at least) double as well. i used note "at least" because thicker wires have comparatively less surface and hence less cooling area.
  4. paul.1911
    Mar 25, 2012
    33
    Hi
    thanks for your turn...
    look here what i got
    This can be use to convert AC to DC
    this will give about 24V out.
    Now can I use 12v transistor to limit volts?
    can a single transistor able Handel so much volts with heat sink attached?
    I don't know how much ampere will be there!!:confused:
  5. R!f@@
    Apr 2, 2009
    8,785
    771
    My dear...do you really know what u are doing?
  6. paul.1911
    Mar 25, 2012
    33
    No :(
    I dont know thats why i want help :(
    what to do?
  7. panic mode
    Oct 10, 2011
    1,328
    305
    reality check: how much power you can get from magneto? if it is rated for 40-50W, you cannot use it to power 100W load and get "full brightness". (if you can, you would solve energy crisis and become wealthiest man on planet)
  8. R!f@@
    Apr 2, 2009
    8,785
    771
    Please explain what u are trying to do.
  9. #12
    Nov 30, 2010
    16,656
    7,296
    Your rectifier drawing has an error. The AC input on the left has a false ground label. It must not be connected to the DC ground after the rectifiers.
  10. R!f@@
    Apr 2, 2009
    8,785
    771
    Do you think OP understands that ?
  11. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Our Terms of Service does not permit discussions on this topic; the relevant paragraph reads:
    These topic restrictions are from the owners of the site, and the restrictions are not open for discussion/review.
    I advise you to leave your wiring exactly as it was when delivered by the dealer. If it has been modified already, have a factory-trained mechanic restore it to factory specifications.
Thread Status:
