how much memory a pointer takes
aamirali
Joined Feb 2, 2012
412
1. how much memory a pointer takes, do it takes memory or it only points to address
2. Also when i declare
int *p
how much memory it takes
ErnieM
Joined Apr 24, 2011
8,377
Yes, it takes memory. Any variable you define takes memory.
How much memory depends on what compiler and what device you're using.
30,801
A pointer is storage for a memory address hence the size of the storage will depend on the memory model of the target computer.
For example, if the MCU has 64k memory space, it will require a 16-bit address.
Hence the pointer will be a 16-bit memory location.
