how measure watt of lighting LED
Discussion in 'General Electronics Chat' started by sendbad, Mar 13, 2015.
  1. sendbad
    Jan 8, 2015
    43
    HI
    i have White lighting LED 3,7 volt 75lm
    but Unknown wattag
    how can i know wattag of thes led
  2. Dodgydave
    Jun 22, 2012
    5,150
    769
    put 3.7V across it and measure the current.
    Lundwall_Paul likes this.
  3. mcgyvr
    Oct 15, 2009
    4,789
    974
    How do you know the Vf and how do you know the lumen output? Did you measure them?
    Without a datasheet/part number/spec it would either be trial/error (aka run it at some current and measure the temps) or possibly measuring the physical size of the LED and comparing to others..
    Post a picture of this LED..
    In general "wattage" really isn't a number you need to know.. Vf and max current rating are the real numbers to use.. With that you can calculate the "wattage".. But IMO "wattage" really isn't a number you need to know to use an LED at all..
  4. MCU88
    Member
    Mar 12, 2015
    360
    35
    And...
    Wattage = (3.7VDC x Imeasure)
    Imeasure is the current that you read on your multimeter.
  5. sendbad
    Jan 8, 2015
    43
    i put it with battry 3.7 v 4.8ma it work for ,30h then lighting drop dawn
  6. sendbad
    Jan 8, 2015
    43
    vf and lm Printed in Base of it
  7. BobTPH
    Jun 5, 2013
    806
    121
    No, it is 17.7 mW. And if you are getting 70 Lumens from 17.7 mW you have the worlds most efficient LED.
    Bob
  8. sendbad
    Jan 8, 2015
    43
    how Calculat it
  9. MCU88
    Member
    Mar 12, 2015
    360
    35
    lol gawd you actually pulled an calculator out and did it?
  10. sendbad
    Jan 8, 2015
    43
    so for 70 lumens what suitable waat
  11. BobTPH
    Jun 5, 2013
    806
    121
    On the order of 1W.
    Bob
  12. sendbad
    Jan 8, 2015
    43
    so with battry 3.7v 4 ah it work for 12 second
    no it work for .3h
  13. BobTPH
    Jun 5, 2013
    806
    121
    1W at 3.7V is 270mA or 0.27 A. A 4AH battery should last about 14H at 1W.
    Bob
  14. sendbad
    Jan 8, 2015
    43
    Direct connection with the battery without resistance work for .3 h
  15. djsfantasi
    Apr 11, 2010
    2,902
    878
    And why did it stop working? Was the battery dead? Was it a new battery when you started your test? Or without a resistor, was the LED dead?
  16. sendbad
    Jan 8, 2015
    43
    without a resistor battery discharg after ,3h and led not dead
  17. djsfantasi
    Apr 11, 2010
    2,902
    878
    Note I asked about the resistor because connecting an LED without one is a sure way to destroy the LED. There are some very specific exceptions, but generally an LED requires a current limiting resistor.
    Did you make your measurements at the points illustrated in the picture below?
    Is this how you got your measurements of 3.7 VDC and 4.8 mA?
    Ignore the two AA batteries... I just used them to represent your battery. (What are you using for a battery?)
    @BobTPH, where are you getting on the order of 1 W? If we are to trust the OP figures (!), your original calculation seems right to me.
    There is so much conflicting /extraneous information here and little hard facts. We need to know
    • What is the LED
    • What is its forward voltage
    • What is its rated current
    • What is the power source
    • How are the measurements being taken.
    • Forgot about the lumens
  18. BobTPH
    Jun 5, 2013
    806
    121
    The 1W comes from that fact the state of the lighting LEDs produce about 60 to 100 lm / watt. If the LED produces 70 lm, it is somewhere on the order of 1W.
    Bob
    djsfantasi likes this.
  19. djsfantasi
    Apr 11, 2010
    2,902
    878
    Hence my conclusion that there is conflicting information. From the data given, there are two widely divergent, yet plausible, answers to how much current is being used...
  20. BobTPH
    Jun 5, 2013
    806
    121
    Yes, there are two conflicts, power used vs lumen output.
    And current used vs battery life.
    Bob
