How many turns number?
Discussion in 'The Projects Forum' started by apolo02, May 2, 2011.
  1. apolo02
    Apr 30, 2011
    9
    How many turn numbers at the primary side of the transformer with a centre taped secondary side producing 14.2-0-14.2v. Input voltage is 220vac.
  2. #12
    Nov 30, 2010
    16,705
    7,358
    There is nowhere near enough information in your question, but (turns out)/(turns in) is approximately how you figure the answer. You will need about 7.74 times as many turns in the primary as there are in the secondary.
  3. Kermit2
    Feb 5, 2010
    3,856
    968
    Set your problem up as a RATIO
    If your 220 Volt primary has 220 turns
    Then your secondary would have 14 or 15 turns.
    Not exact but close enough to work with.
    If your primary has 50 turns
    50 /220 = x/14
  4. apolo02
    Apr 30, 2011
    9
    Also can diode add voltage in a centre taped transformer? For example from 10-0-10v to 12-0-12v how can i use it 2 add output voltage?
  5. #12
    Nov 30, 2010
    16,705
    7,358
    You can't. Diodes don't generate voltage.
  6. Kermit2
    Feb 5, 2010
    3,856
    968
    Diodes are used to RECTIFY the AC voltage into DC voltage.
    apolo02 likes this.
  7. apolo02
    Apr 30, 2011
    9
    Kermit2,my problem is on what exactly we mean by turns,and how can i measure that this is a single turn.so pliz help me.
  8. kubeek
    Sep 20, 2005
    4,691
    806
    For a standard EI transformer, 1 turn is one complete loop around the middle post. The actual number depends on area of the center post, voltage and frequency you want it to use with.
  9. wmodavis
    Oct 23, 2010
    737
    150
    True! Diodes don't generate voltage but they can, in conjunction with capacitors, be wired into a voltage doubler circuit. Right?
  10. #12
    Nov 30, 2010
    16,705
    7,358
    @ wmodavis Not the way this guy wants it. Look at post 4. He wants to add 2 RMS volts to each winding. You simply can't teach a diode to do that.
  11. apolo02
    Apr 30, 2011
    9
    I simply want to connect a diode on each end side of a centre tap transformer just b'cos my transforme normally generate 6.3v-0-6.3v and i want it 2 generate 7 volts to each side in the secondary side so that to get 14.3v-0-14.3v can diode generate? If not so what can i do to get that amount of voltage?
  12. kubeek
    Sep 20, 2005
    4,691
    806
    The transformer generates 2x6.3V AC? And you want to get 2x14.3V DC?
    Then a voltage tripler could get you near that. What current can the transformer supply and how much do you need?
    Remember you can´t get more power than the transformer is rated for.
  13. wayneh
    Sep 9, 2010
    12,406
    3,256
  14. apolo02
    Apr 30, 2011
    9
    Ok! Thanx 4 ur advice.bt the transformer still work with a shortage of voltage,so i will work on it later coz i dont have enough time 2 repair it again till when am at hom coz now am tight with school.so thanx 4 ur advice i wil work on it,thanx am from TANZANIA
