How are the coupled coils connected? I.e., what is the actual schematic look like?For better selectivity I have used two coupled inductors (not shown). The second col is wound on a cardboard tube of smaller diameter (try plastic or aluminum wrap rolls) that slips inside the larger toilet roll coil. Then I can adjust the desired coupling by sliding one coil over the other. The diode is connected to the second coil. The selectivity is superb. I can easily pick up four stations at 900, 1010, 1150 and 1280kHz.
