How many electrons are in 1mA ?
Discussion in 'General Electronics Chat' started by RRITESH KAKKAR, Jan 16, 2016.
  1. RRITESH KAKKAR
    Thread Starter Senior Member
    Jun 29, 2010
    2,831
    89
    How to find electrons flowing in few mA current?
    example: 1mA how much electron are there?
    charge on electron is = 1.6 x 10^-19C
    Q=N*e
    N=q/e
    N=1/1.6x10^-19
    n=0.625x10^19
  2. DickCappels
    Aug 21, 2008
    2,753
    665
    Can you take a try at this first? I think your question is best worded as "How many electrons per second does 1 milliamp represent."
  3. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    1ma = 0.001A
  4. ISB123
    May 21, 2014
    1,240
    531
    If there is 6.25 10^18 electrons at 1A/s how much there would be at 1mA/s?
  5. Alec_t
    Sep 17, 2013
    5,961
    1,133
    I think ISB123 means 1 Amp.sec and 1mA.sec.
  6. Roderick Young
    Member
    Feb 22, 2015
    408
    168
    One Ampere means that on average, one Coulomb of electrons are passing a given point per second, going in the same direction. If the same electron loops around and passes that point again, it counts as another one.
    One milliamp is 10^-3 amp, which means that 10^-3 Coulombs are passing that point.
    A Coulomb is a large number, about 6.24 x 10^18.
    So one milli-Amp means 6.24 x 10^15 electrons per second passing through a given point.
    JohnInTX likes this.
  7. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    Then what is Voltage ?
    10V 20V are they presure or moving speed of electrons?
  8. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
  9. Roderick Young
    Member
    Feb 22, 2015
    408
    168
    Voltage can be thought of as pressure. Current can be thought of as volume of flow. The actual speed of individual electrons is not something that usually matters in electronics, although it might in physics. Although an electric field propagates at basically light speed, electrons have a surprisingly low average velocity in the wires in our electronics, I've heard.
    If this is homework or for a test, be very careful about units. Current has the units of charge / time, in the above case, electrons per second. In a casual conversation, an engineer might know what you mean, but it is technically incorrect, and would likely be marked wrong on a test.
  10. crutschow
    Mar 14, 2008
    13,472
    3,361
    Yes, the slow movement of electrons in a wire at typical current levels is because there are many more free electrons in a volume of the wire conductor (assuming 1 per atom) than there are in a coulomb of charge moving through that conductor.
