I'm working on a project that uses nearly 7-8 amps max from a car battery (~12V).
I need something like a remote latch, so that I'm able to open and close the circuit by using a remote.
After some searching I found this device, that I think is cheap and seems to fit my needs:
http://www.rfremotech.com/RR1LNV2.pdf
I found the datasheet of the relay it is using, and it says that it can drive 10A @125V AC, so I think that I shouldn't have problems in my scenario (correct me if I'm wrong please).
I'm only a bit concerned about the output pins (near the relay) I should connect my battery to. Two of them are just used to power the remote latch, but the other three are directly connected to the relay: do you think they can handle 10A?
Thank you!
Thank you!
