how long will it work
Discussion in 'Physics' started by aliashar86, Mar 29, 2008.
  1. aliashar86
    Thread Starter Active Member
    Nov 23, 2006
    71
    i have to glow bulb using salty water. so for how much time will it remain glow
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    I think you will find that producing current will take more than just salt water.
  3. aliashar86
    Nov 23, 2006
    71
    sorry couldn't understand
  4. aliashar86
    Nov 23, 2006
    71
    ok tell me that edison faced the problem regarding the oxygen gas due to the absence of which the filament can;t glow. so tell me that there is also no gas present inside a bulb so then how it continues to glow.
  5. veritas
    Feb 7, 2008
    167
    the problem that edison ran into (in my understanding - I could be completely wrong) is that in the presence of oxygen, the filament would oxidize and break/burn. It was the lack of oxygen which allowed the filament to last for an extended period of time.
  6. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Edison's bulbs were pumped down to a hard vacuum to preserve the filament. Modern bulbs are full of argon gas.
    I had assumed that the salty water was for an electrochemical cell to produce current. If not, what about the salt water is going to make the bulb glow?
  7. aliashar86
    Nov 23, 2006
    71
    thans dude
