How long will 4000 and 74 last?
Discussion in 'Off-Topic' started by Robin Mitchell, Dec 30, 2009.
  1. Robin Mitchell
    Oct 25, 2009
    738
    207
    Hi guys,
    Yeah, How long will 4000 and 74 series last as in, when will they stop making them?
  2. hgmjr
    Jan 28, 2005
    9,030
    214
    The answer to your question would take a pretty good crysal ball to determine. This is a market driven dynamic. As long as it is financially attractive to manufacture these and any other devices, the maker will keep producing them.
    hgmjr
  3. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
  4. Papabravo
    Feb 24, 2006
    10,340
    1,850
    It will not be sudden, but it will occur in dribs and drabs over the next two decades. What will be the most popular parts is hard to say but if I had to guess it will be octal buffers and octal flip-flops and latches.
  5. Wendy
    Mar 24, 2008
    20,772
    2,540
    Looking into my Crystal Ball I predict we will be able to make our own simple (under 1000 transistors) chips or equivalents in 20 years, similar to how we make home made PCBs now. There is a lot of experimentation using inkjets to make circuits using organic dyes (organic LEDs and transistors).
    Even if it isn't practical for home use, there is a very good chance small houses will spring up that will make small custom runs on demand.
  6. loosewire
    Apr 25, 2008
    1,584
    435
    If you go wikipedia for the 7400,when you scroll down to
    the breadboard curcuit,click your mouse over the board
    and an over lay will appear showing how the curcuits are
    arranged with names.
  7. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    The availability of inexpensive uC's will eventually cause most (if not all) of these 4000/74xx series IC's to go away.
    Some of the more useful ones will hang around for quite a while though, particularly items like Schmitt-trigger NANDS and the like. Shift registers will hang on too, as that's an easy way to multiply I/O pins of uC's.
  8. Papabravo
    Feb 24, 2006
    10,340
    1,850
    It is interesting to note that many common functions are available in CPLD devices, but parts with 4000 series electrical characteristics are not very popular with the programmable device crowd. In fact I don't think I've ever seen one.
