How long can a mini relay stay energized?
Discussion in 'General Electronics Chat' started by kgstewar, Jul 27, 2013.
  1. kgstewar
    Apr 5, 2012
    151
    6
    I have one of these little relays and would like to use it to switch on a circuit that draws about 2 amps at 12V. My question is, how long can the relay stay energized at a time? My worry is that if left on too long the coil will overheat. Is that a valid concern?
    http://www.taydaelectronics.com/datasheets/A-5014.pdf
    Thanks!
    Kevin
  2. Dodgydave
    Jun 22, 2012
    5,167
    777
    A 12v coil takes 30 milliamps, no way will it heat up...
  3. MaxHeadRoom
    Jul 18, 2013
    10,867
    2,528
    ...or dissipate 36Mw.
    Max.
  4. mcgyvr
    Oct 15, 2009
    4,793
    976
    years and years
  5. MaxHeadRoom
    Jul 18, 2013
    10,867
    2,528
    I'm not so sure about that...see where it's made!!
    Max.:)
  6. mcgyvr
    Oct 15, 2009
    4,793
    976
    Well yes that i agree with.. But usually the crappy relays just have problems with repeated switching (or frankly even switching at all) and seeing as this is just an on for good deal 99% of the time I wouldn't worry too much about it.
    But yes personally I ONLY trust Omron, American Zettler, TE(axicom) and Hasco relays. Omron is #1 and you pay for that ranking though.
  7. mbohuntr
    Apr 6, 2009
    413
    32
    YUP! I ordered 5 Hong Kong reed relays for an alarm system, and now I have 4 as one has already started latching up after 10 cycles... :rolleyes:
  8. Ramussons
    May 3, 2013
    562
    92
    360 mW :D
    Ramesh
  9. MaxHeadRoom
    Jul 18, 2013
    10,867
    2,528
    Right, I missed a zero!
    Max.
