how large this Distance vector can be
Discussion in 'Computing and Networks' started by lse123, Feb 10, 2011.
  1. lse123
    Thread Starter Active Member
    Oct 17, 2006
    87
    In Distance Vector Algorithm (RIP)
    A row in routing table is itself a Distance vector, well, how large this Distance vector can be? As it’s direct links (neighbors=subnets) only?
  2. lse123
    Oct 17, 2006
    87
    that I mean is, in routing table row how many numbers of the vector(like coordinates), can exist?
  3. Papabravo
    Feb 24, 2006
    10,340
    1,850
    No idea what you are talking about.
  4. thatoneguy
    Feb 19, 2009
    6,357
    718
    RIP isn't recommended for large networks (15 Hop Max for your 'vector').
    Take a look at ICMP for larger networks.
    If you are working on routing between two routers, the physical distance doesn't matter, as long as it is within specs of the physical layer. If you have many routers and large tables, RIP becomes very inefficient.
    BGP isn't used until you are on background links, it's designed to "route around" failures, more efficiently and quickly compared to ICMP. Do you have a network sniffer?
  5. lse123
    Oct 17, 2006
    87
    As DV tell, it's neighbors the cost, from it to all nodes knows about in his network area, these all data where go? in neighbors routing table or this is for only neighbors?
  6. thatoneguy
    Feb 19, 2009
    6,357
    718
    Here is the RIP RFC which explains it pretty well.
    Animated RIP Simulation/Tutorial that might help.
    RIP takes up a lot of bandwidth with broadcasts and routing table updates.
    I have no clue why I posted "ICMP" instead of "OSPF" above, sorry for that error, Acronym Storage Area must be full. RIP isn't used much, often replaced with OSPF (Open Shortest Path First), as stated above.
  7. lse123
    Oct 17, 2006
    87
    again: As DV tell, it's neighbors the cost, from it, to all nodes knows about in his network area, these all data where go? in neighbors routing tables or these tables are for only neighbors data? In other words exist, separate routing tables for neighbor data and, for non-neighbor data in each router?
  8. lse123
    Oct 17, 2006
    87
    Distance Vectors vs (destination IP - first Hop), saved in separate tables, what is called each?
