http://www.youtube.com/watch?v=RkTvDjhImwo&feature=player_embedded
Theories welcome... not my video!
I like the filter idea but seems too complex.
Riveting video, watching someone wire up a circuit.http://www.youtube.com/watch?v=RkTvDjhImwo&feature=player_embedded
Each switch has a filter in it (low/mid/high), the switch shorts out the filter disabling it. Each LED has an LC filter hidden on it. This tunes the LED to the filter. The battery is fake and a wideband noise generator.What filter? Am I missing something?
I think it is obvious that it is not wired as shown. Something must be hidden from view.
Look at how tall the LEDs are. There would be room for SMD filters to be inline. Also, the "Red" is a bit brighter red, like red tape at the bottom edge of them, and there's no ledge on the bottom edge.Each switch has a filter in it (low/mid/high), the switch shorts out the filter disabling it. Each LED has an LC filter hidden on it. This tunes the LED to the filter. The battery is fake and a wideband noise generator.
Or it's Adobe After Effects...
But the switches would still need to turn on the filters somehow and they appear to be in series. Unless that is all fake too and there is a small mcu or something the selects each oscillator.Look at how tall the LEDs are. There would be room for SMD filters to be inline. Also, the "Red" is a bit brighter red, like red tape at the bottom edge of them, and there's no ledge on the bottom edge.
Battery would have 3 high frequency oscillators in it.
Unless there is a PIC10F200 underneath the tape on the LEDs and in each switch. Flipping the switch just sends a different signal.But the switches would still need to turn on the filters somehow and they appear to be in series. Unless that is all fake too and there is a small mcu or something the selects each oscillator.
I noticed that too. Do you think that's why his circuit is broke?This guy does not know how to solder properly. Please do not solder the way he did.
If it is Edited:It could also be touched up video. The LEDs were sitting still, it would be easy to retouch the picture to make the same effect.
Another thing that occurs to me is that the circuit is laid out on a wide loop, positioned seemingly rather carefully. Could there be some kind of induction loop or coil hidden under the table, designed to induce AC voltages in the wiring to the LEDs - perhaps at more than one frequency to allow tricks to be played with resonance?@zzmgck You're right. Schematic is only the overall representation of main task: answer, how I can control this LEDs ? All components at the film has been modified (except battery).
Solution is really easy. Many people have already found it
Fredzislaw100 3 days ago
He posted in the comments that he would reveal how he did it at "some point in the future"If it weren't video magic I would tend to lean toward the induction method myself.
by Aaron Carman
by Duane Benson
by Jake Hertz
