How is Capacitor tolerance for power supply determined
paprider
Joined Jun 23, 2015
5
I have a 230v to 15v converter module which specifies to use 0.1uF/50v and 47uF/50v capacitors at its output.How do I find the tolerance value required?How are generally this things decided? I have attached the datasheet of the power module.
34,409
Those are filter/decoupling capacitors and their actual value is usually non-critical, so parts with any available tolerance for their value will be fine.
paprider
Joined Jun 23, 2015
5
Thanks.So you mean to say that the values are randomly selected?If in case tolerance is critical, how does one find out the correct value?
