How is a segment illuminated in a typical 7-segment display?
Discussion in 'General Electronics Chat' started by kgstewar, Feb 1, 2016.
  1. kgstewar
    Apr 5, 2012
    151
    6
    Consider a common 7-segment display, like this one. I noticed in the datasheet schematic, they show one LED per segment, which may just be schematic, although for a larger display they show 3 LEDs per segment, so maybe they are showing the actual number of LEDs per segment. In any case, here is my question:
    How is a display segment in a 7-segment display constructed such that one LED can uniformly illuminate the entire segment?
    I have tried to make my own LED segment by putting an LED behind some partially translucent white acrylic. I always get a fairly localized bright spot and not the uniform illumination that you get in a 7-segment display. Maybe I just need to line up more LEDs for each segment? Or is there a trick?
    thanks,
    Kevin
  2. hp1729
    Nov 23, 2015
    2,105
    235
    I think all possibilities are apparent. Consult the data sheet for the display you are considering.
  3. dl324
    Distinguished Member
    Mar 30, 2015
    3,389
    653
    The cavity the LED is in is filled with a material that diffuses the light emitted by the LED. The surfaces of the cavity are also reflective.
    Your results will never be as good as a display that considers angles of reflection and the interface between the LED package and your difusing medium.
  4. kgstewar
    Apr 5, 2012
    151
    6
    Thanks, any idea what the material is that they use to diffuse the light emitted by the LED? Maybe an epoxy with a characteristic refractive index? I'm happy to experiment.
    I'm trying to make displays with unconventional shapes (perfect circle transected by 2 lines, for example).
    thanks!
  5. dl324
    Mar 30, 2015
    3,389
    653
    It's a glass filled epoxy resin with the color chosen chosen for optimal optical transmission based on the wavelength of the LED die in question.
    You might check with a company like VCC that sells light pipes to get some ideas. I've seen light pipes used in a lot of equipment. Sometimes they shape/difuse the light from a discrete LED; other times they bend the light 90 degrees.
    You might also opt for a panel in front of the LED with a cutout in the shape you desire.
  6. kgstewar
    Apr 5, 2012
    151
    6
    I was doing some googling and ran across this product (and a few others). Seems like it may be effective at diffusing the light from individual LEDs so that I might be able to create my own more-or-less uniformly backlit LED displays. I'll give it a try and report back.
