how i know whether my car battery is full charging??
Discussion in 'General Electronics Chat' started by hcchuar, Dec 19, 2008.
  1. hcchuar
    Nov 8, 2008
    23
    i'm using below circuit to charge my car battery,how i know wherter my car battery if full charging?because i do not know how to confirm it
    another problem is my schokkey diode is getting hot after a min for charging?anyone know how to solve this problem??My input is 16V to 18V, 2.++A
  2. leftyretro
    Nov 25, 2008
    394
    By measuring the battery terminal voltage, 12.6 is considered fully charged.
    Lefty
  3. hcchuar
    Nov 8, 2008
    23
    ic..................so just i need to switch off the charger first than only can measured the voltage right? Between the charging progress, is it the voltage i measured on the battery is the charging voltage?not the battery voltage?
    do u know what way to make my shokkey diode to avoid heating?
  4. leftyretro
    Nov 25, 2008
    394
    Yes, switch off charger, wait a while for battery to cool and settle, some suggest waiting 2-3 hours, then the measured battery voltage will reflect it's state of charge. Here is a link with a lot of information on charging lead acid batteries:
    http://www.batteryuniversity.com/partone-13.htm
    How hot is the diode getting? Can you touch it for more then a few seconds? Is it the type of diode case that can be bolted to a metal heat sink?
    Lefty
  5. hcchuar
    Nov 8, 2008
    23
    thanks for ur link,is there got any method to know whether my battery is charging full while the charging system is in progress? so that i can switch off my solar panel........to avoid spoil the car battery, the car battery i'm using is distilled car battery (12V33Ah)
    my shokkey diode is SB560, data sheet as below
    http://www.datasheetcatalog.org/datasheet/wte/SB520-T3.pdf
    i'm using DC power supply to simulate the circuit first before i'm trying on solar panel, i'm try on 15V,2.2A, after 30 seconds, the shokkey diode will be getting hot and hot, after few minutes, the level of hot is even cannot touch the diode by hand,is there my circuit wrong or wat? my transistor (2N3055) still cool without heatsink
  6. hcchuar
    Nov 8, 2008
    23
    my shokkey diode without any metal or heatsink? is there got any heatsink for diode?
  7. flat5
    Nov 13, 2008
    403
    17
    Am I the only one who thinks this circuit looks terrible?
  8. hcchuar
    Nov 8, 2008
    23
    then do u have any good suggestion? because this circuit is too simple,i do not know whether can be working well or not ..........how do u think this circuit is terrible?
  9. hcchuar
    Nov 8, 2008
    23
    do u have any good suggestion on this?because this circuit is too simple,i do not know whether can be working well or not,how do u think this circuit is terrible?
  10. flat5
    Nov 13, 2008
    403
    17
    I'll wait till others respond. I'm not an expert.
    Edit: 4 hours later.
    I don't know what the internal resistance of the solar panel is but shorting out the panel to control the voltage does not seem elegant.
  11. Audioguru
    Dec 20, 2007
    9,411
    896
    You must not use a regulated power supply to power the simple circuit because then the shunt voltage regulator won't work and the voltage and current will be too high.
    Then guess what happens to the Schottky diode and the battery?
    A solar panel is a current source and it is normal to shunt it to drop its voltage when the sun is very bright. I have a 12V solar panel that produces 18V with a low load current.
    The transistor should be hot and need a heatsink so I don't think it is working.
  12. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Are you certain that you have installed the Schottky diode with the cathode towards the battery's positive terminal? There is a ring around the diode on the cathode's end.
    Audioguru's correct - you need a current-regulated supply instead of a voltage-regulated supply to test your circuit.
  13. leftyretro
    Nov 25, 2008
    394
  14. floomdoggle
    Sep 1, 2008
    217
    What you are looking for is a dump load circuit. An automatic electronic circuit that will stop your charger charging when it has been fully charged. But will continue to use the charging power. Your circuit will shut down at full charge, but will have a problem with the continued power input. That is where a dump load comes in. When your battery is fully charged, your circuit has nowhere to get rid of the excess power, except to block the incoming power.
    Not a good thing.
    Dan
  15. leftyretro
    Nov 25, 2008
    394
    " but will have a problem with the continued power input. That is where a dump load comes in." "your circuit has nowhere to get rid of the excess power, except to block the incoming power"
    Load dumping is only a problem needing a solution with mechanical power generators like wind generators or hydro generators. A solar panel does not have to 'dump' it's load if there is no current being drawn from it, so load dump does not apply or needed for solar cell applications. If you leave a solar cell out in the sun, but have nothing connected to it do you think that you need to have a load dump installed?
    Lefty
    Lefty
  16. hcchuar
    Nov 8, 2008
    23
    yes...........the schottky diode with cathode towards teh battery's positive terminal
  17. hcchuar
    Nov 8, 2008
    23
    Thanks for the link,but i have some confusing on that, LM350 is the variable voltage regulator, so i need adding few component so set the output voltage? is 14.5V? or this circuit already include all component? i'm not quick understand about it
    Based on the documentation, trasistor 2N3393 is use for LM117, do u think that LM350 also using the same transistor?
  18. hcchuar
    Nov 8, 2008
    23
    anybody can answer me?
  19. floomdoggle
    Sep 1, 2008
    217
    Lefty.
    The OP, among other things in his (her) circuit needs is regulating. Part of any charging circuit, mechanical or solar needs a way to stop. The dump load is part of that circuit.
    Dan
  20. Audioguru
    Dec 20, 2007
    9,411
    896
    Your new circuit has a lousy old 741 opamp with its input voltages too high. The circuit probably used an obsolete opamp that worked fine with its inputs near its positive supply voltage. A newer TL081 opamp will work.
