how i get it?..
Discussion in 'General Science' started by skyskysky, Dec 13, 2014.
  1. skyskysky
    Nov 29, 2014
    12
    my question is ..what is mean 30C and 1.5 bar file it mean the presssure 1 and 2 bar is P2..and T..how i can get it..
    can show me plez..how i get the ans..?
  2. atferrari
    Jan 6, 2004
    2,672
    785
    My questions:
    Where do you study and what metric system do you use at home? When you need to express temperature, what scale do you use?
    Are you sure you do not recognize the symbol "º"?
    Did you know that if you enter those symbols, Google could tell you more than what you would like to read in your whole life?
    Are you kidding?
  3. skyskysky
    Nov 29, 2014
    12
    no..just i want to understand..
  4. skyskysky
    Nov 29, 2014
    12
    this ans my ans it correct..
  5. GopherT
    Nov 23, 2012
    6,329
    4,069
    The equation you have on the right is perfectly correct.
    However! Gas equations are worked in degrees Kelvin, not Celsius. Add 273.15 to convert Celsius to kelvin.
    When you complete your calculations, subtract 273.15 from your answer to convert back to degrees-Celsius.
  6. skyskysky
    Nov 29, 2014
    12
    amm..so 30 c + 273.15 = 303.15 then calculate it by useing that law..and then
    the ans will be for T2 is 224.5 ..!!
  7. GopherT
    Nov 23, 2012
    6,329
    4,069
    @skyskysky
    Yes, in degrees Kelvin.
    So, convert back to degrees Celsius by subtracting 273.15.
    skyskysky likes this.
  8. GopherT
    Nov 23, 2012
    6,329
    4,069
    Also, it is bad question because it makes one think that the compression causes the new temperature and pressure.
    Compression normally causes a gas to heat up. Therefore, after compression, heat would have to be removed from the system to achieve the desired pressure to lower the temperature.
  9. skyskysky
    Nov 29, 2014
    12
    ok..
  10. skyskysky
    Nov 29, 2014
    12
    amm...so it will be T2 is 224.5 + 273.15..is it ur mean ?
  11. GopherT
    Nov 23, 2012
    6,329
    4,069
    No,
    Think about this...
    - You are compressing the gas from 1.8 volume down to 1.0 volume (compression factor of 0.5555)
    - If the temperature were to remain constant, you would expect the pressure to nearly double
    - according to the Problem, The pressure only goes up from 1.5 to 2.0 (1.33333 )
    - this means that the temperature must drop (it must drop a lot).
    If we were at a constant temp, volume ratio change would be the reciprocal of the pressure ratio change. Multiplying them together would give us 1.00000
    Instead, 0.5555 x 1.3333 gives us 0.740xxxx
    That means the energy of the gas must be reduced so it does not make as much pressure as we expected at our new volume. Like reducing pressure of a balloon by putting it in the freezer makes it smaller!
    Since multiplying out pressure change factor by our volume change factor is less than onE, that means, our final temperature must be COLDER than out starting temp (303.15) to have that little pressure. In fact, our final temperature should be initial temp 303.15 x 0.760x = 225.5.
    Final temperature must be 224.5 - 273.15 = -48.65
    No gas went in or out of the system,
