how I can solve this problem use calculator fx-991ES
Discussion in 'Math' started by micro1, Mar 8, 2016.
  1. micro1
    Feb 22, 2015
    53
    how I can solve this problem use calculator fx-991ES or fx-991ES plus
    sin( X -0.36 ) + 0.353*e^(-X / 0.377) =0
    answer x= 3.5
  2. WBahn
    Mar 31, 2012
    18,085
    4,917
    I don't know about your calculator, but it might have the ability to do numerical solutions.
    But you can do it with any scientific calculator (or even by hand with trig and log tables) using an interative approach in just a handful of iterations.
    The two obvious starting points are X=0 and X=0.36.
    The first one results in
    sin(-0.36) + 0.353 = 0.000726
    while the second yields
    0.353* e^(-.36/.377) = 0.1359
    Notice that at X=0.35 the value of the expression is 0.001625, which is more than twice the value at X=0. However, X=0 is a local minima and doesn't actually touch zero, whereas there is an actual zero at X just slight greater that 0.35 (at about 3.5016).
    There are a number of games you can play using trig identities and variable substitutions to tease out information, but there is analytical solution (that I am aware of).
  3. WBahn
    Mar 31, 2012
    18,085
    4,917
    Oh, and note that there are an infinite number of solutions that, as the exponential dies off (quickly) are separated by very close to 2pi.
    anhnha likes this.
