How I can increase current
Discussion in 'General Electronics Chat' started by murock, Jan 9, 2014.
  1. murock
    Jan 9, 2014
    10
    I current have 3.6mA going down a wire, but I need to get up to 5A to drive a large device. I've heard I can use drivers to do this. I came across a Darlington Array but I'm not sure I how to implement this. Any ideas or suggestions of where to look would be great.
  2. MikeML
    Oct 2, 2009
    5,451
    1,066
    What is the supply voltage for the high current load? (Where does the 5A come from?)
    What is load resistance? (Or what is the load?)
  3. murock
    Jan 9, 2014
    10
  4. MikeML
    Oct 2, 2009
    5,451
    1,066
    Your link requires a log in.
    I still need the igniter voltage when 5A is flowing through it?
  5. MikeML
    Oct 2, 2009
    5,451
    1,066
    Actually, now that I have seen the schematic, you need a voltage controlled switch, like an NMOS transistor. Presumably, you want current to flow through the igniter when the output pin of IC6b is high?
  6. murock
    Jan 9, 2014
    10
    Yes thats exactly what I need
  7. murock
    Jan 9, 2014
    10
    How would I wire one to get 5A through the igniter?
  8. murock
    Jan 9, 2014
    10
  9. MikeML
    Oct 2, 2009
    5,451
    1,066
    What NFET did you use?
    Something wrong with your modified schematic. With 20V to the igniter, if it takes 5A, its internal effective resistance would be R=E/I=20/5=4Ω.
    Your 1Ω would draw I=E/R=20/1=20Ω.
  10. 4pyros
    Jan 3, 2014
    22
    Mike I think you have a typo, should 20 ohms be 20 amps?
  11. 4pyros
    Jan 3, 2014
    22
    Looking at the data sheet for the DR9020 igniter the resistance is 0.65 - 0.9 ohms.
    The typical all fire current is 5 amps. This could be more or less.
    You need to remember the igniter is almost a dead short so most firing systems use drivers that can handle at least twice the current needed for all fire. Also igniters can short out after they are used so you should plan accordingly.
  12. MikeML
    Oct 2, 2009
    5,451
    1,066
    Yep. Sounds like you know more about igniters. Can you suggest a driver circuit that he can trigger from a 9V CMOS gate?
  13. murock
    Jan 9, 2014
    10
    It just says its an ideal N type MOSFET.
    Even if I remove the resistor I still get a smaller current than I need of 400mA which doesn't change even if I up the voltage.
    http://imgur.com/MTOCrpZ
  14. murock
    Jan 9, 2014
    10
